Today I did my heavy run. hauling 2 horses and pulling a garde here called Camario Grade. Its long ans steep. My first motor could pull it in thrid gear but sometimes in second too. Now I was in 1st gear and gv over. I just barely made the top. Coolant was 215 degrees but lots of black smoke. Pyro was low arounf 800 degrees. Seems like the motor is not making hp at all. I did turn down the moose pump about 1/4 flat. SDtill lots of smoke. Even unloaded and not hauling anything getting up to speed on the freeway it smokes. I am running "G" code injectors and 9.6 dbtdc. The injectors were pop tested by me at 1950 lbs. I'm really thinking the injectors are not doing the job. Thinking about BB code injectors. I really don't know what else could be causing the low hp and black smoke. It is almost starting to sound like something is wrong with the motor. I will be running a compression test and probably changing the injectors but just can't get a handle on this problem. I do have a spare injection pump but really don't want to try that just yet. I feel the moose pump is doing its job. My last comp test showed 530 lbs on all cylinders. Two were 520 but that was close enough to be concidered the same across the cylinders. So what do you guys think might be the problem with low hp. Too much timing... Bad injectors... Comp low...
Air cleaner has 5000 miles on it so its clean. Its a custom S&B element...
