RWettstein
I have an 86 F350 with a 6.9idi and only 65+K miles but a lot of years. Had a lot of white/grey smoke that would increase to the point it would hardly run. A mechanic friend told me to check the check valve on the IP and it was full of debris (metal and fiber). Cleaned it out and it ran pretty well. Then it would do it all over again and I would have to clean it again. Replaced the IP and runs better but still smoking and running rough at higher throttle but doesn’t want to stall. Nothing in the check valve anymore. Lift pump only has about 4 1/2 pounds pressure when running from the tank at idle. It drops to zero and probably negative when increasing throttle. I’m sure that’s to be expected. All the lines are clear back to the tank and new filters. Runs a little less smoky out of a clean jug of fuel direct to the lift pump. I have not checked the pressure while it is running from the jug. I cracked the lines loose at each injector one at a time and they all seem to make it run worse. Also, no discernible sound difference from one to the next when holding a rod to the injector. I don’t know if the lift pump is too weak(I doubt it has a couple hundred miles on it) or if there is debris in some or all of the injectors. I only make a few deliveries of mulch a year with it anymore. A little help would be appreciated. Thanks
