eastsideauto
The 3 small bolts that hold the ip to the gear. What do they torque at?
25 ft lbs is the torque on those. they are a 12 point 5/16 hex head. Same as the rear universal joint bolts. BTW you can buy those at Nappa in a u-joint repair kit for our trucks. they are a special heat treated bolt so don't worry about the seemingly high torque value...
7ft lbs seems more like the torque for the bolts on the access cover for the gear bolts.
My thoughts are if you have no real experiance and really want the torque to be "close" to what you want or need... Use a torque wrench thats been calibrated once a year. Most torque wrenches have directions telling you to drop the pressure and don't store it with pressure on the spring. My 40 year old Craftsman click type wrench instructions tell me to set it for 10 lbs during storage. Never leave it higher than that. Care of a click type torque wrench is as important as the torque value your asking of it. I tipically use a torque wrench on the head bolts. The rods and the mains mostly. The front and back of the crank gets the same care when tightening too. But very seldom does anything else get torqued down on my engines. I have developed that "feel" for most bolts. I have never torqued the valve cover bolts or the water pump bolts. I just have a feel and don't see the need for torqueing those bolts.
