Welcome to the site. The reason you had so much trouble posting, is that you tried to put this in our tech articles section. Wrong forum! I know that was just an honest mistake, but I'm sure you wanted an explanation. I got you fixed up here, and hopefully you will find your way back.
As for your question, have you read our FAQ (top of this forum) where we have information on buying a used IDI? If not, please check that out. The fuel system will be fine after 2 years, provided that the fuel did not have organisms in it, and that they have not grown and clogged everything. You will probably need a fresh pair of 950CCA batteries, a new fuel filter, fresh fuel in the tank, and a lot of understanding as to how the fuel system works in these trucks. I'd suggest reading the fuel system servicing article in our tech articles forum (I know you know where that is
) to get some ideas, then read up on how the glow plug system works, and try to determine if this farmers truck has an original glow plug system, or if it has been converted or hacked by someone who may or may not have known what they were doing. Also look at the glow plugs and determine if they are Beru, so you get a feel for the likelyhood of sucessfully replacing them, if they test bad.
