mblaney
I made a simple modification to stop the GP controller from cycling after engine start. I think the controller is programmed to keep GP's hot (cycling) for too long after starting for emissions BS; this puts a lot of wear on the controller relay.
My mod is simple enough; I tee'd in an oil pressure switch (part number SP64) and ran the controller white wire through it. (this switch has three connections, NO and NC, you need to use the NC).
I am extremely happy with the results; on a cold start (-20 C) I get about two cycles after starting. When hot, I can start right up (say after a visit to the diesel pump) and the GP is OFF as soon as I have oil pressure.
I figure this reduces GP relay cycles by 60 - 80% and probably adds life to the GP's themselves.
... so that is 16 GP's off the bat... add in a few other occasional drivers
