Mr Roboto... First of all to make a 1/2x14 bolt you will need to turn it on a lathe because nobody makes a die nut in that size and thread. There is a big differance in the bolt body size between a 7/16 and a 1/2 inch bolt. Now just if you were to turn down a bolt that had a 1/2x14 thread instead of a 7/16x13 thread the body diameter will be too big to fit thru the head where the 6/16 bolt fits. Now if it was a stud then maybe it might work because the 1/2x14 threads would fit into the block and not need to pass thru the head. But still the block can't be drilled to fit the 1/2x13 or the 1/2x14 threads. Not enough metal left after drilling. Fabricating a fully machined special bolt that has been turned on a cnc lathe still wont work because nobody has a tap that will match this special bolt you have made. Just buy the arp studs. They will work fine.
