Severe duty fan clutch
Socal88
San Diego,Ca
Anyone ever installed or use a severe duty fan clutch, does it really make that big of a difference or work better? And was there a different fan for this application. I've read up on the 6.0 fan mod for the Powerstroke, but that's the wrong rotation for the IDI. Would like to more CFMs across the radiator.
Any opinions?
The original 23 inch diameter fan moves plenty of air, if you can buy a clutch that works. I haven't seen anyone on here mention any clutch for these trucks that works like they think it should, severe duty or not. If you come up with a solution everyone will be wanting to know about it. I locked mine fan on and it works now.
ifrythings
BC
I did, use a 6.4L cutch and control it how you like it, does require a threaded bushing to be made to run it though.
If you got a bunch of those adapters made, that might be a viable swap. I would not do the complicated control for it though. A simple on-off or maybe a two step control.
ifrythings
BC
The bushing is the hard part of the swap and anyone with a decent lathe could make them, all I have is the little 7x12 Chinese lathe and I don’t think I could make them on there. The control part is cheap and easy even going beyond just a switch, an Arduino, sensor and a few other parts and you have a fully functional fan controller or a $2 switch works also.
