jhenegh
Truck Still Earns its Keep
As currently setup with a pickup bed, when the turn signal on a certain side is on, it uses the same bulb/filament as the brake light. This gets rid of the brake light on that side while it is flashing. Right?
I am putting a flatbed on my truck so I can use as many lights as I need/want to on the back. I'd like to use separate brake and turn signal lights. Can this be done with existing wiring or is the same wire used for both the turn signal and brake circuit?
I like how GM uses separate tail, brake and turn lights and I'd like to do the same thing on my truck.
Pictures for example of GM taillight and what I'd like to do on my flatbed with light arrangement.
