running a SD PS pump instead of the old bricknose one?
Greg5OH
MI
Wondering if this has been done before? My biggest concern issue would be if the V belt pulley will fit on the new SD pump shaft? I can get dimensiuon soff the new pump, coudl someone provide shaft dimensions off the old pump please?
Some of the van pumps were the good ones. Forget the pump name, same as the chevy's with hydro.
Easier to make fit a serpentine setup.
Sent from my SM-G900R4 using Tapatalk
Greg5OH
MI
im not looking to go serpentine, im looking to run my V belt pulley
Greg5OH
MI
innnteresting. I shall confirm this once i get my truck town down in next few weeks.
hmm, don thtink its a c2 pump..
thois is wha tmy new pump looks like
can someone get me the shaft diameter of the old idi pump please?
Greg5OH
MI
i will go to oreieleys today and measure the shafts of the two pumps. Need to warantee my impact socket, grrr
Greg5OH
MI
didnt take the pulley off my SD pump, however i measured a new C2 pump, the shank diameter is .685
i was getting around .675 or so for the SD pump jsut using the vernier and eyeballing. So-most likely it is the same diameter.
I hope it is not smaller as that will make installing the V belt pulley more difficult and i would have to make some kind of sleeve.
jaluhn83
Upper Marlboro, MD
Might want to check the shaft with a metric caliper - I would not be too surprised if the idi pump is fractional inch (11/16" it looks like from your numbers) and the newer pump is a metric shaft.....
Greg5OH
MI
i wouldnt be surprised. I need to get the pulley off and check for sure. miight be able to do it today
tke395
