RoyBoy
Diesel Nut
Well as some of you know, I have traded in my old '04 "Shorty" so I got some stuff to sell!
6- Toyo M-55 tires, 255/85 R16 with only 5,000 miles on them. The front 2 are at 90% and the rear 4 80%. These will work on your stock Ford duallies and not touch, yet are a 33" tire. These tires are around $300 EACH new. $1250
2- Truck trunk side mount aluminum tool boxes. They are 10" wide, 10" deep, and 64.5" long. They are low profile- only stick up above the bed rails around 1". Very high quality riveted boxes, they are around 6 years old. Could use a good polish job and one is missing a support stud, otherwise they are in good shape. $500 for the pair
Ford AIC with bracket and harness, works good. $200
SCT xcal2 with 3 Gearhead tunes and 3-4 Elite tunes VXAP1A4 TQAT0QA code. $300
Pullrite Superglide 24k 5th wheel hitch. I have it set up to connect to a B&W gooseneck hitch. Or you can get the brackets from pullrite to install it in your truck. Also will include the adapter plate off the trailer. This is a very nice hitch and it hasn't been used that much. $1500.
