Well i am in the process of eliminating the mechanical fuel pump with a new Carrier unit i got from Doug (GenLightening) . And after fighting to get the mechanical pump out i realized the supply lines were pretty rusty , So i decided to replace it back to where there was good tubing to splice new 3/8 I.D. hose to to run to the new electric pump . The previous owner eliminated the saddle tank and was just running off of the rear tank ( this is a cab and chassis F-superduty with a dump bed ) and in doing so he bypassed the original 3/8 metal hard lines and used what i think is 5/16 brake line for the supply and the return lines . The supply line has numerous splices that i want to eliminate , The supply line coming out of the tank has the factory push-lock fitting but is a 5/16 hard plastic inside of a rubber jacket , It was about 12" long and from there it was multiple splices of rubber and steel line to the factory pump . Now what would be the best way to go about replacing the line ? can i just run a 3/8 rubber line from the tank barb to the electric pump or do i need a push-lock fitting coming from the tank barb and then to 3/8 rubber line ?
