I replaced the injectors and IP today and started the truck now when I turn key to off the engine won't shut off. Still seems to have knock too. Any help is appreciated.
Parts came from R&D IDI and I hooked wires up as they were to the IP I gave up for the night so it hasn't been timed yet just thought it was odd it wouldn't shut engine off.
Key on, engine off, connect and disconnect the FSS terminal. Do you hear it click each time? Also, try starting it with the FSS terminal disconnected. If it runs, FSS is stuck.
