According to the manuel:
"4. Coat the rear engine cover seal bore with gasket and drim adhesive.
5. position the new seal in the bore with the spring side of the seal facing in, then carefully install the new seal. NOTE, the seal must be installed from the engine block side, flush with the seal bore iner surface.
6. Apply a 1/8 inch bead of RTV sealant around the outside diameter of the real seal and edge of the real cover."
Marq
________________________
If you got a bad head gasket, over torquing will not fix it, and you may break something. A lot of people don't realize what torquing actually does. Each bolt has slight stretch to them, that's what hold them in place. The torque value is the ultimate stretch point in which the bolt will hold. To little, and the bolt does not stretch enough for a proper hold. Too much, and the bolt looses its stretch/holding properties and at a point, will break. If anything, over torque will fatigue the holding ability, and you should at that point toss it. As for the mechanics. Back in the days, any body could and did turn a wrench, but like doctors and lawers, there's the good, bad and the ugly. These days, you have to be a rocket scientist to be a good mechanic, the dumb ones get recalls, while the real mechanics win races and events; and know how to do a job right; always doing proper prep and research, and making sure there's no short cuts, and that'll do her approach.
Marq
_________________________________________
1990 Ford F-250 4X4:
7.3 IDI with 120K on the clock:
ATS Turbo with waste gate:
Stage One Injectors (Oregon Injector Service):
Complete Return Fuel Kit (Oregon Injector Service):
DB2 Pump, cranked up with Cold Advance wired permanently on:
4” down pipe, 4” straight through exhaust stopping between cab and bed (no fuff on my stuff):
Torque Converter Lock Up Switch (On/Off/Lock-Up):
E4OD Line Pressure Controller (adjusted to fast/firm shifts):
4” lift w/Rancho shocks:
Big Fat Tires on custom rims:
Tows 1985 fully loaded heavy 28 foot RV (my house) everywhere:
