Dane Rickford
Hey guys, I am trying to resolve yet another issue that the P.O. did before I got my truck. When I got my rig the mechanical diesel lift pump had been replaced by a inline electric pump mounted down on the frame just in front of the front fuel tank. Everything works as it should, only when the P.O. installed the electric pump they went directly from the front tank to the fuel filter, meaning only the one tank is usable. I am planning on just putting on a transfer pump that pumps fuel from the rear tank into the front one.
My question is, would it be alright to tee the supply line from the rear tank into return line on the front tank? Or would this create return line pressure?
Also the transfer pump will be on a switch so it won’t be running all the time, only when I need to refill the front tank.
