If the bearing burned into the differancial whats going to be left after you have it apart. Its like spinning a main bearing. Not only does it ruin the crank but it ruins the block too. Learning you ran low of oil because of a leak kinda tells me the rest of the gears and bearings are suspect too. May as well just replace the complete differancial. Cheaper and quicker. Mostly 8 u bolt nuts. 4 universal joint bolt or nuts. A brake line and a parking brake cable. If you end up replacing the differancial please don't reuse the spring u bolts. Many here will tell you they are a one time use only. If you want to save them leave them alone on the axle and take the springs too. Then you save loosening 4 bolts.
