lastbugle
I put new brakes on my truck 92 F250 4x4 last year I put new seals on them and right away the seal blew out driver side only, and greased up the brakes a quick note I confess when I put on the new seal it didn't exactly feel right but seemed right also.
Any way I took it apart and tried another new seal aftermarket same one as before only this time I really looked it over and found it didn't go on at all without destroying the seal so I get a factory seal from ford and it fit great definitely looked right also didn't see any kind of grove or ring on hub where seal goes put it back together and the other day brakes started smoking after using and pulled it apart and seal went bad, brakes greased again any ideas what to do or try.
tired of buying new brake pads not cheap?
