Well, I got my 12 1/4 inch clutch kit today and the Banks downpipe.
The clutch pedal bracket in the parts truck was cracked to hell so I went to picknpull and pulled one out of an F150 for $16.99. Got that installed and put in the steering column from the parts truck. It has good tilt and cruise, but without the auto shifter.
The Diesel gauges are in, and pretty much all the Diesel specific parts.
I picked up Oil Cooler O-rings and gaskets today, and mounted the switch for the GPs.
For the tranny crossmember I ended up using the bushing from the C6, and moved the crossmember back about an inch or so to the next holes back. Then I used the passenger side crossmember/frame bracket from the parts truck that had the 2wd ZF. It used the same holes in the upper part of the frame, but angled back more to meat the crossmember in the rear holes. This gives me the 41"s from the passenger motor mount to about the middle of the slot in the tranny crossmember, still leaving room for the ZF to droop down in the front of the crossmember. By the way, the pass side motor mount is about a 1/2" different from the drivers, that messed with me for a while.
Just need to get my Turbo back from Russ
![Hail Almighty :hail :hail](/styles/default/xenforo/smilies/hail.gif)
, and a few exhaust/intake parts. The, the Beast should be alive!!!
