'94IDITurbo7.3
HAMMER DOWN!
any body got any tips to make it successful. mainly so i don't break anything.
thanks
thanks
The easy answer is send it to Ruff... Usually they come apart easy but somethimes they stick too. Then once you have it completely apart measureing all the important parts is whats next. Now buying the correct well made parts is the tuff issue. As Russ has found out rebuilding turbos that were rebuilt with cheap import crap parts. Sometimes you have a real ****** on your hands. Then finally these turbos need to be balanced way closer than any other rotating equiptment. They will spin upwards of 120,000 rpm. Thats 2000 rpm per second. Make a 100th of a gram mistake and you have lunchmeat for a turbo. I can do plenty of machine work but rebuild a turbo.. Nope... Not even interested in that. For me its much to easy for a mistake that takes out the turbo. When the inlet compresser wheel destroys itself on the housing all that metal goes into the cylinders. Not a good thing at all. If the hot wheel contacts the housing so what. It goes out the tail pipe or out the stacks. I'm sure if you ask Russ for pointers he may offer some.
Eric now would be a great time to upgradethat downpipe while tour in there![]()
New development.
yesterday my dad was asking me if it would be a good time to upgrade that down pipe. trying to not sound too excited i said "as a matter of fat, yes it would be a GREAT time". then he asked about the rest of the exhaust. my response to that was i guess it would be a good time.
then i showed him how i could upgrade the exhaust out let by welding a 3 inch v-band flange on there. he also like that.
so while my turbo is out in Oregon. it looks as though i will be getting a MIG welder, a couple of v-bands, and this exhaust.......http://www.diamondeyeperformance.com/product_info.php?cPath=17&products_id=185
i am going to the system from discountexhaustsystems.com. will be about $300.00 shipped to my door.
so right now i am a happy guy and a tad bit excited.![]()
