agp23109
Anyone know if the fluid resivor from a stock 1 1/8 master cylinder will fit on an 1 5/16 master cylinder found on the super duty?
From what I have read not sure where the article is but reusing the original master cylinder requires that the mounting holes be elongated/sloted a bit to fit.
THats not what he was asking. HE was wanting to know if the plastic tank from the original MC would push into the holes of the replacement SD sized MC. Some new and rebuilt master cylinders are sold without the plastic tanks.
That said, a brand spanking new SD size MC with a new plastic tank is only around $28
I got it at advance. I thought it was a rebuilt and brought the core back and me guy tells me it was NEWWhere did you get one for $28? I have an 1 5/16 mc but no resivor. A quick eyeball check of the 1 1/8 tells me no go. Autozone tells me its a dealer item and the stealersship wants $94.00 for JUST the resivor cheaper at this point to get a mc with a resivor.
And for clarification im currently running hydroboost with 1 1/8 mc and although it's better than the vacuum booster I think there's more to be had with the 1 5/16 mc. I'll keep you posted with the results for anyone considering the swap or who's done it and stayed with the 1 1/8 mc like I did.
Thanks for all the replies
if you can make the drive down to santa clara, I have a couple of used hydro master cylinders with the reservoirs still attached.Where did you get one for $28? I have an 1 5/16 mc but no resivor. A quick eyeball check of the 1 1/8 tells me no go. Autozone tells me its a dealer item and the stealersship wants $94.00 for JUST the resivor cheaper at this point to get a mc with a resivor.
Thanks for the offer but with fuel prices the way they are it's cheaper to just return my resivorless mc and buy one with a resivor. The difference is only $10 or $15. Thanks again though.
Swapped master cylinders today. And YES the master cylinder makes a difference. Huge difference between the two. Anyone considering the swap should not even waste their time with the stock master cylinder. Just bite the bullet and get the 1 5/16 mc to get the full potential out of the hydroboost swap. Thanks for all the replies!
