at this point on a Saturday night, maybe i should be posting in the "hammered posters" thread, but...
has anyone noticed that his sig does NOT say he's running a turbo? if i am assuming correctly, John, you have a naturally aspirated (non-turbo) 6.9 - correct?
i see "Banks Power Pack A/C lid" in your sig, but that's just a cool hat for a N/A, right?
i say your pyro is spot on if my assumptions are correct. IIRC, when i installed my pyro, i could push 1050 empty (but i had to try HARD). {remember AT this summer Ron?
open up the intake even more than that Banks hat (see my garage or diesel_dog_catcher 's post) & i bet your EGT's go down. add WMO to the fuel tank & they'll go down another 50*. keep your air filter very clean. i believe an open exhaust may help some :Sly . my 246k OE pump is screwed 4 flats, BTW.
sounds like my probe is about where yours is (first pic). my temps don't sound too far off from yours either (second pic)... i will tell you that when i first installed my pyro, i thought my temps were outrageously high. after watchinfg it a day or so, i realized that i would have to really work the truck to keep the temps up anywhere close to the dangerous range for any amount of time...
currently, i run about 550* @ 2100 rpm @ 75 mph on level ground. that can quiclky go to 900* if i'm standing on the go pedal up a decent grade.
i suggest you take a long drive & play with the pedal & watch & see - maybe add some weight to the bed for a little test?
