Pulled a 1987 out of a hole
Flange for the driveline at the diff may be different, but it should be a direct bolt up.
WrenchWhore
Lake Havasu City
As long as it has the rear diff sensor on top of the axle housing it should bolt right in! The only other difference I see would be the T19 gear ratio might be deeper than a diesel T19. The rear axle I used to swap out my original 87 axle was a 4:10 limited slip out of a 93 gasser. If it's a 250 4x4 it should be the HD44 stuff on leafs.
Mine is a Dana 44 HD was 82 also a Dana 44hd?
You should be able to tell by looking at the hub size. 44 has a very small locking hub, 44HD is larger, and 50/60 is huge.
As for rear window, I believe they are all the same from 1980-1997
captain720
Washington
Yes I can tell by looking at, it’s a few hours away and my 6.2 F350 with a trailer pulls like a train but it’s not afraid to drink some fuel so I am trying to get all the info I can ahead of time thanks guys! I appreciate all the input.
captain720
Washington
I got a parts truck! Except it’s too good and now my truck with the bent frame is the parts truck…………. I will be using the nice studded 6.9 out of my 87 to diesel swap this 91.
It’s a gas F350 4 door 4x4 with a 460ZF and a blown up 460. The 460 ran good enough to go around the yard and test the 4by and make a couple shifts, wouldn’t go into reverse not sure if it’s clutch plate disengagement or a internal problem.
But did this one come out of a hole? It's hard to beat a truck that was in a hole.
captain720
Washington
Here is the video, I know the first post about this truck was light on photos so I am trying to make up for lost time.
I did an idi swap on a 460, wasn't too bad. Hope you have fun!
