MJlogan
Pulled a turbo setup off a '96 ford van in of the junkyard with the intent of retrofitting it on my '85 6.9. I got the exhaust manifolds, pipes to the turbo, and the turbo itself. Ideally i would like to put the turbo in the same location as it sat on the PSD using the factory manifolds and pipes. The manifolds look very similar to the IDI manifolds. Anyone know if the manifolds bolt up for sure before I go tear apart my my daily driver for a test fit? I realize the PSD and IDI have different heads, but i figured i might get lucky. And at $15 per manifold from the junkyard i figured it was worth a shot.
thanks
thanks
