Waystro
No Class
So figured I would start a new thread for the 85 so here goes
Truck info:
85 F-250 4x4 D50 6.9/C6
Seems to have had a engine fire drivers side fender panel is melted wonder what caused that? Probably the Po when he installed the cheap air horns.
Engine says void on valve cover anyone know what that means??
So here's a basic list of what I need to do.
Flush all fluids
change belts-hoses
change thermostat
Valve Cover gaskets
Install the Racor Fuel water separator
change ignition switch
install manual GlowPlugs
Replace Cowl Seal
Brakes front and rear
Block Heater
Prep Rims For Paint
Install GlowPlugs(thanks Bill)
Install Injectors(Thanks Brian) and Return lines
And Install the passenger side axle shaft.
Thats about all for now.
Engine Mods:
Turbo 088 or Banks
Moose Pump
Moose Misters
Headstuds
Truck info:
Flush all fluids
change belts-hoses
change thermostat
Valve Cover gaskets
Replace Cowl Seal
Block Heater
Prep Rims For Paint
Engine Mods:
Turbo 088 or Banks
Moose Pump
Moose Misters
Headstuds
