Made a little progress. Cleaned for several hours. Still haven't found that damn bushing. Anyway, I pulled the old driver hinge off with the classic ford broken door holder. There was a little surface rust behind it so I sanded it down, dabbed a little metal prep on it, shot a little primer and paint on it.
Bolted the hinge up loosely, and hung the door back on.
Couple notes. There is a long and short hinge pin. Long in the bottom, short in the top. I figured this out when I screwed up and put both long pins in one side. The replacement I bought was an Evan fisher hinge. The pin does not come out of it. This could be real inconvenient if the door needs to come off with the fenders on. Otherwise, it seems to be a decent piece.
And the other side.
I lined them up pretty close but there is some fine tuning to do.
Now to decide what's next.
