Got a vacuum pump from the local salvage yard, from a 88 F250, which had a V-belt pulley.
When I tried to put my serpentine pulley on it did not go.
Went to local machine shop, they measured the pump shaft from the 88 F250, it was 17mm, the ID of the serpentine pulley was 16.60 mm.
Has anyone else run into this problem, and how does a person fix this?
Would honing the pulley work?
When I checked Oreilly's site, the same part number (for a replacement pump, without pulley) is used for both the 88 & my 93.
Thanks all.
Thanks all.
