The Warden
MiB Impersonator
Hello! Finally get to take a few minutes' breather from school to post this.
Thanks to towcat, I now have a ZF5 that will be seeing its way into my truck after it gets rebuilt. Since this didn't come from a complete donor truck, I now get to start assembling parts.
Any suggestions on a supplier for rebuild parts? Besides the standard bearing/syncro kit, I know I need shift forks and the lower gearshift unit (the one the "main" lever bolts to), and there may be more once it's opened up. My buddy who's doing the rebuild may also need a manual, if the shop at his school doesn't have one.
So far, I know for a fact that I need a gearshift lever and a floor pan insert. I'm going to pull a floor pan insert off a truck tomorrow, and I think I "get" to go junkyard hunting for a gearshift lever. Just wondering, how far off is the cutout for the ZF compared to the T-19?
I've heard in the past that the ZF5 transmission crossmember is different from that on a T-19. I asked towcat about this last night, and he wasn't 100% sure how vastly different it is (been a while since he's had a need to compare the two), so is there anyone who can say either way? Can the one from a T-19 be adapted? What other tranny/engine combos might use the same crossmember?
I clearly also have to re-do the clutch, and it looks like the T-19 flywheel is also a no-go (not necessarily a bad thing; I've been needing to replace the ring gear ever since I got the truck). Any suggestions on what route to go here? towcat has a few old DMFW's (that are probably in need of a Lucky mod), and I may be able to snag one, but if the cost isn't prohibitive, a SMFW conversion sounds like a nice idea.
I know I'm missing something
Any input would be greatly appreciated...
Thanks in advance
Thanks in advance
(thanks again towcat) Just need the rebuild components, the crossmember, the gearshift lever, and the clutch stuff now... I spent some time looking on Luk's page, and wanted to double-check...the wider the diameter of the clutch disc, the better, right (due to extra material)? If so, $$ depending, that's leaning me more towards the SMFW...but I still need to figure out how much the clutch stuff is going to cost...
