power steering fluid cooler.
ok i have a personal issue.
ford liked to use mass quantity's of hard line that i personally find no bueno.
looking at my truck today, i would like to delete the loop on the front cross member for the
power steering fluid.
i will also be running a hydroboost set up.
any of you run a fined type cooler here instead of the stock loop?
I don't have much to offer but I do recall I think it was bike maker who had ran the PS through the AT cooler loop on the rad and it was a no-go. Fluid starvation issues I think. I was thinking of doing the same thing so I took note.
:popcorn
no mufflers
rhode island
yes I have, in the proses of swapping motors in my plow truck, 79 f250, I used a power steering cooler from a 06 GMC 1500. it fit pretty good on the front cross member where the old lines were, and I plowed all winter with no problems.
jhenegh
Truck Still Earns its Keep
Deerfield, WI
I'm running a finned cooler. My truck had a small one (like 2"x8") when I got it. I now have put in the bigger the ford factory E4OD finned cooler for my power steering and a bigger trans cooler from a 7.3 superduty. Hanging a 800lb snow plow on the front makes the steering work hard. I've done close to 200 billed snowplowing (foreign to you CA guys, I know) hours, wiht a lot of it being slow speed parking lots, and more just driving with this setup and have no issues.
FarmerFrank
Blairsville, Pa
A finned tube type cooler is good, a plate type is not.
My farm truck has a Saginaw pump from a van and a used a tube type cooler. Thing steers amazing.
My bronco I used a transmission plate type cooler with 35's and a factory pump. Maybe 1500-2000 miles on that set up and the pump is about shot, hard steering at idle. That's just what my findings are, plate types don't flow enough.
got a pic?
You may want to check out what Jaguar did for power steering fluid cooling on the V12 engines. They had a small finned cooler picking up air flow from the v belts. Odd place to pick up air flow but I guess it worked. they also has a fuel cooler too. It was run off the ac freon loop. I can't say that was a good idea because what is cooling when the ac system is turned off.
Tube and fin like factory old trucks etc.
Also since going all in...add a small spin on filter setup too to increase volume and clean fluid.
JM2CW
dunk
Dunce
NJ
Yes. It is necessary when running larger/wider tires or fluids overheats and the power steering fades. I use a big cheap tube and fin type on mine. Anything is better than that loop which gets caked in mud and rusts out.
no mufflers
rhode island
there she is. I run it all winter and do 25 to 30 driveways every storm.
jhenegh
Deerfield, WI
And some more. Aluminum plate is trans, black tube/fin is steering. It used to be my trans cooler.
chris142
SoCal
The stock tube on the cross member uses the whole cross member as a heat sinc.
jaluhn83
Upper Marlboro, MD
Disagree - there's no good thermal conductivity between the tube and crossmemeber - there's almost no conductivity since it's mounted on plastic spacers.
