JeffMoss1
Jeff
Hi Everyone,
I haven't posted in a while (or worked on my Van in a while), but now I'm back on it. Not sure why I haven't gotten rid of it yet, I just like that thing for some reason.
I will try to keep this concise. Basically I'm looking for confirmation from maybe a few of you that I have this diagnosed correctly. Below is the sequence of events:
- A long time ago replaced head gaskets. Forgot to put in one of the little grommets on the felpro gasket on the passenger side front of the engine.
- While I knew I had done this, the motor worked great for 4-5 years, so I didn't fix something that wasn't broken.
- 2-3 years ago it got bad and I knew what the problem was, but didn't have time for it.
- Van has ended up sitting quite a bit.
- Finally got around to replacing both head gaskets and the coolant no longer bubbles (pretty confident that the cooling system is sealed now, but feel free to question)
- Drove the van around and there was major white smoke and poor power.
- Checked timing with my timing light and the injector line clamp sensor.
- Timing was retarded below spec pretty far and I couldn't advance the pump any more than it was.
- Bought a new IP. Installed it and timed it.
- There was definitely water in the oil, so I did an oil change before I started it up this time, but the oil was cold, so it might not have been that thorough of a change.
- Power is great.
- Odd noise at a seemly specific RPM. Sounds like a piece of sheet metal rattling. Really hoping it's not the lifter spider coming loose or something in the motor.
- Ignoring that for the moment, there is a HUGE plume of white smoke coming out of the exhaust. The more throttle, the more smoke.
- Popped off the air filter and there's a major amount of smoke coming out of the CDR and going right into the intake.
- Inside the CDR it looks like a clogged artery. White, milky goop.
- Put on an extra (old) CDR had lying around, didn't fix the problem.
My Diagnosis:
There's a whole bunch of crud and water inside the crank case and that all needs to burn off for the smoke to stop.
My Plan:
Warm it back up, drive it around, do another oil change, smoke slowly goes away?
I welcome any and all comments. Feel free to tell me to get rid of my stupid van and get a truck. I might not listen to you though. ;-)
- Power is great.
My Diagnosis:
My Plan:
