Pinion nut loose AGAIN!
MontanaJack
Helena Montana
THATS IT??!!!! No more posts? I read every post just find no answers? Argh! Your last post says your truck was doing the exact same thing mine just started doing. Did you solve the issues? What was the problem and how did you fix it? Also, what size of socket is needed for the pinion nut? Gracias
BDCarrillo
Abilene TX
The sterling pinion adjustment info is spot on in here. I did my 2009 truck at about 130k and it took between 300 and 400 ft lbs to hit the right preload
JU57US
