Parking Brake Cable Replacement- And maybe a cure for your weak parking brake.
agp23109
Vacaville, CA
After 21 years my front parking brake cable snapped. This is the cable that runs from the pedal to the intermediate cable. It snapped in the area where it leaves the firewall. Learned something interesting while replacing it and thought I would pass it along.
First and foremost if you're replacing the brake cable make sure you remove the pedal assymbly from the wall. At first I fished the brake cable through the assymbly while it was still attached (PITA) just to find I ultmately had to remove it. Three bolts, no big deal.
After I got it all hooked up I found that the cable was about three inches too short :mad:. I was lucky enough to purchase my truck from the original owner who was a mechanic and took impecable care of the rig. He was kind enough to give me the actual Ford shop manual for the truck. So I went to the manual, where I probably should have began. Shockingly I learned that yes you need to remove the parking brake pedal from the wall to install the cable. I also learned that our trucks have a self adjusting parking brake pedal to keep everything tensioned just right. I found that I needed to unwind the tensioner in order to get cable to reach. Followed the procedure and it didn't work. Tried several different times, removed the pedal assymply twice, pulled as hard as I could, nothing worked.
As I was fighting the pedal for well over an hour, I noticed a white plastic clip wedged into one of the rachet levers on the pedal. It seemed odd to me that that this little piece was the only plasitc in the entire pedal assymbly. After manny a cuss words and reading and re-reading the shop manual, I turned to this site.
After a quick search I learned that back in 1994 Ford issued TSB # 94V169001 (Sorry, I forgot who the OP was:sorry:). The TSB dealt with the self adjusting paring brake pedal. Apparently the rachet gears would slip causing the pedal to release. Not good, especially if you have the ZF5:eek:. The fix? The fix was that little plastic piece I noticed was wedged in the ratchet gear. This disabled the self adjusting mechanism. I removed the plastic wedge and what do you know, I was able to release the tensioner! Got the cable all hooked up and then reinserted the wedge and I was good to go.
What I found was now my brake pedal goes about a 1/4 of the way down and is rock hard. Parking brakes set like concret;Sweet. Since I have had the truck I have dealt with a weak parking brake. I keep the rear brakes adjusted and have read numerous posts on this site looking for a remedy. Obviously Ford came up with the self adjusting pedal to deal with the minor amount of slack and strech in the cable that happens from repeated use. My guess it the original owner of the truck had the TSB taken care of back in 1994. When that happend it disabled the auto tensioner. That meant there was 19 years of slack in the cable :eek:. I read several posts that said if the parking brake goes more than half way to the floor before it sets something is wrong. I agreed, I just never could figure out what that something was until yesterday.
Thought I would share this info with other people in case you are either replacing your parking brake cable or dealing with a weak parking brake. I'm not sure which year Ford came out with the self adjusting pedal. However, if you are replacing the parking brake cable you will need to remove that wedge to complete the job. Just be sure to reinstall it to keep it from slipping. If you are haveing an issue with your parking brake not setting very well, even with your pedal to the floor, you might want to check to see if you have the self adjusting pedal. If you do chances are the TSB was taken care of and that plastic wedge is preventing it from taking up the slack. If its there, remove the wedge and operate the pedal a few times. This should tighten it up. Just remember to reinsert the wedge!
Hope this helps, and prevents someone else from pulling their hair out trying to figure out why they can't get the tensioner to release:rolleyes:
I'll snap a pic of the pedal and wedge later today and update this post so people can see what I'm talking about.
crewchief219
Wichita, KS
Great timing for this article! I just replaced everything in the rear brakes including the parking brake cables but the front cable wouldn't reach so I saved it for another day. Haven't taken the front apart yet, I was thinking it was frozen like the rears. Now I have something else to check before I throw parts at it. Thanks!
U FORGOT PICS....this forum is addicted to PICS....:dunno
GREAT article and should likely be in tech section!
warhog
TN
Neat. And How much did that cable run you?
agp23109
Vacaville, CA
Cable was $12.99 from the local parts place. Can be had for around $7 from Rock auto but I didn't have time to wait for shipping.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Good info ;Sweet
FWIW I'm pretty sure that started in '92 with the introduction of the OBS trucks. Certainly, the OBS parking brake pedal assembly's completely different from what Ford used between 1980 and 1991...
LoveMyIDI
Washington
I know this is 13 years old but hopefully someone searching can use it.
I had the same problem and I couldn't find any pictures on line.
After taking the assembly off I located it by the top of the pedal arm!
It's small and fragile so gently wiggle it out!
Oh look! Someone's truck has three headlights!;Poke Seriously, welcome to the forum and thanks for posting pictures.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
Another problem affecting all of us likely 1980 to 1997 is that all of the brake shoe cores in circulation for all new and most reman shoes are made incorrectly in the parking brake actuator area. In the area at the top of the shoe where the parking brake actuator wedges the brake shoes apart to force them against the drum there is metal missing due to sloppy mfg. that allows the actuator to completely miss one shoe and nearly miss the other. After hunting all over hell for shoes that were made correctly, I finally grabbed the MIG and built up the shoes to match the originals in that area. A little grinding and filing and presto better than new park brake! Ran into this 3 times now.
Selahdoor
Index Wa
Another thing I'd really like pics of. Especially a comparison pic or two. :D
The_Josh_Bear
Western WA
Got a measurement/spec by chance? That's not something I've heard before but I believe it to be accurate. No matter how tight my rear drums are at the star wheel I still need a good amount of pedal travel to get the brake to keep from rolling if on anything beyond a small incline.
Selahdoor
Index Wa
So... How do you release the tension, once you pull out the plastic piece?
ttman4
Last Nite's Dream..
Another problem affecting all of us ....
This little plastic parking brake pic thingie got my curiosity up, as well as Garbage Mechan comment about fixing the brake shoes.
I like my Fords, but I keep learning & getting ideas from OB & one of these days I think I may just build me a new truck brand from bumper to bumper. Don't know what I'll name it, but it'll be better than Ford, Chevy, Dodge.....& maybe FINALLY I'll be rich????
Selahdoor
Index Wa
Ok, forget my questions here. Mine doesn't have this plastic piece. Or even the place to put a plastic piece.
jrollf
Houston, TX
There really isn't a 'place' for it. They plastic piece jams in-between two parts preventing the tensioner from operating.
I found out I had one when a mysterious broken piece of plastic appeared on my floor board. Someone on the forum identified what it was from a pic I posted.
FYI Ford doesn't make the plastic part anymore. I had to search eBay for a NOS part. I also heard it might be possible to pull the parking brake pedal out of a newer truck not subject to the TSB/Recall and use it.
1993 F350 Crew Cab Dually
XLT
7.3 Factory IDIT w/Banks Sidewinder
5spd Manual
morerunner
Staff online
