parallel turbos
1mouse3
il
In to the almost empty scrap pile of metal bit...
I find something that can be split in two...
That gives enough work area to plot a radius...
Then to plot somemore cuts...
I think @chillman88 would like to play with this...
Now to fold the edge...
Then broght it to a 3in radius...
Now have one of the two fillers made...
I would like the tip here, but not with a 45 bend. Am going to see about gettin 60 degree one, also its spun with the peak pointing to the back.
Its only a bare poke and has uniform shape here.
1mouse3
il
Sir, put down the welder before someone gets hurt.
;Poke
I am not the welder and you dont complain about free...
Now lets see what there is to work with, there is some thing on back side...
On the front there is a bit of slober and the welder was complaining about no filler...
So cut the slober off...
Then shoved the grinding disc acrost it. Was going to get to the back side, but misplaced the tools for the die grinder.
Playing the game, that's where I'd put it.
But realistically looks like it needs to mirror the one on the right
1mouse3
il
@Nero Id groop like kind since fit most efficent. Oh what was I doing, that right, I went over these with the die grinder...
The back took some creativity like, chisel and the die grinder not doing much. One spot got a small cut off to, that found a hole as well...
Ether way cleaned that up with a die grinder. There is places that will see if the welder can try again at.
1mouse3
il
Far left, no rotation!
So you would like to count your eggs before they hatch? I see playing for that path, youd be waiting for like kind to spawn. Chance could be against you, where your stacking pieces on one side of the board. Say In this state you would be scambling to make stuff fit,
1mouse3
il
Well these brakets got touched by the welder for a second time...
Its a far bit better now...
So repeat with grind disk...
And then the burr...
Even with what is done with the other side, this is good enough to send.
Aw **** here we go again
I find the best way to play tetris is to build an even structure on one side or the other, but leave a 1x gap on the end, to use a straight piece to get a tetris.
1mouse3
il
To each there own and fair enough, if that works for you.
Did I push too many buttons?:joker:
Tetris is a good pass time for me. I did recently get myself a used NES to play tetris. But I debate, I think the super Nintendo nes/Dr Mario is better.
ISPKI
Granby CT
Mouse, do you have a 4 1/2" angle grinder? If so, take a look at a pack of flap discs from Benchmark. They take metal down much faster while providing a better surface finish than a pneumatic die grinder. Only time I pickup my die grinder now is if I have to get into a really hard to reach space.
Benchmark Abrasives
tke395
