so i vacuumed down the system last night, i at least think i did the whole system, honestly i dont knwo maybe i onyl vacuumed down the low side hose..how can I tell if the whole system is under vacuum?
I attached a screw on fitting to the low side which is on the dryer port, and i used a quick coupler connector on the high side port between compressor and condenser. Strange-because i didnt think R12 systems had those red quick coupler connectors.
Anyway, the manifold gauge set I have does not have a purge valve on the yellow charge hose, nor does it have shutoff valves at the hose ends. I see some do, some dont, which confises me how do I go about actually charging the system now.
Envirosafe doesn't want a vacuum, ok. Soak cans in hot water to get pressure up. connect to yellow side, have both red and blue valves closed. open the can, turn truck on turn AC on. AC compressor wont cycle untill enough pressure is met.
So now do I open both blue and red valves? ONly blue? I dont know how this manifold is built. I assume the high side does not fee the low side at all through the manifold?
