2stroke
What do you think will it work on our 6.9 idi
This can be seen with a picture at bronco grave yard.
Dont know if torque rating is enough.
Item #31525 - New!
Ranger Torque Splitter Overdrive unit
For use on 1971-87 4-Speeds
The Ranger Torque Splitter is an auxiliary gear box that bolts to the front of the standard Ford 4 speed transmission.
This fully synchronized unit allows you to split your gears at any time.
Features:
27% overdrive.
The unit is cast aluminum
It measures 7 1/2".
Helical cut gears
Short throw manual shifter
Built to handle 420 ft/lbs of torque
G.V.W. rating of 25,000 lbs
Weighs 82lbs
Has 1 year warranty from date of shipment
Ships UPS ground.
*RANGER III TORQUE SPLITTER OVERDRIVE FOR USE ON FORD MANUAL TRANSMISSIONS HAVING A 4.848 BELLHOUSING INDEX DIAMETER. OVERDRIVE RATIO IS 27%
Our Price: $1345.00
Item #31525 - New!
Features:
27% overdrive.
It measures 7 1/2".
Helical cut gears
Weighs 82lbs
Ships UPS ground.
Our Price: $1345.00
