Oil leak from GP relay?
awardmont
houston texas
Hello, i was checking oil last night on my 1994 f350 7.3 Turbo IDI 290K,
, and noticed what looks like fresh golden oil leaking out from GP relay all the way down exhaust manifold to frame and ground.
i recently added 2 qts rotella, I dont drive 500miles a year, only to keep in running condition.
Any thoughts appreciated.
awardmont
houston texas
Thanks for the reply, Would a GP Relay replacement take care of this?
Do relays include timer also?
Thanks Again,
Your solid state glow plug relay is failing. Time to replace. Napa or ebay will get you what you want. Ebay will be cheaper but make sure you purchase an oem part. That relay can be bad from the start because of cheap import parts.
