FastestIdIinthe707
What came off was Orange rtv and a gasket that looked like it had been on there since 94 when it was made
What happens when you use rtv on these gaskets is the rtv is slippery and the gaskets can move under clamping pressure. then you have a mees inside and outside the engine. As posted.. The gasket has red sealant already applied from factory. Use it and enjoy. I ALWAYS place the heads of any surface on a flat plate and some 400 wet n dry paper. Rub it a few times and look see for high and low places. Nothing worse than a leak.
Its too late for tin foil now Al...... We got you already micr chipped..........
I'll double check.Looking at that pic closer, that's not actual rtv. That's off the gasket.
Looks like anyways.
Sent from my SAMSUNG-SM-T337A using Tapatalk
