Truck buffing really nice bluish smoke at idle and randomly in a way , smells like it's burning 2 rich, the buff can burn your eyes to be honest if the window down , This syndrome happen at stop light or in the drive way specially when it gets up to normal op temp but non when i am running ,If i stump on it , It picks up & go with nice black buff .
The turbo drain been re routed to Valve cover of the driver side , There is no major sign of oil loss per 5k miles maybe less than 1/2qrt per Oil change , Truck has 139 on the clock . The down pipe does not appear discolored as if it's oil soaked.
At one point i ran road tube under the truck which had it covered with oil mist ,So i put it back to the CDR ...It's almost 6-9 month old CDR ..
Is it Turbo seal
Is it worn out Rings
Is it 2 old
Is it IP outa time
Is it leaky injectors
Is it blow by that is traveling to the CDR and burned inside the intake ...
My CDR collect some oil like a shot worth
IP and injectors all Original
Thanks
Is it Turbo seal
Is it 2 old
Is it IP outa time
Thanks
