I've been putting more thought into running WMO since WVO is starting to become prohibitively expensive to obtain. I'm going to talk about first my filter choices and the filter mounts followed with the ratings found on the stock filters. My engineering and data source for all this is from Wix filters and you can verify by going to www.wixfilters.com and entering the part numbers in their search engine.
The first item is a electric fuel pump. Currently, I'm using a rotary vane type pump out of a gasser putting out 5-7psi. It's used and didn't cost anything but when it does die, I will be switching over to a 10-15psi unit designed for thicker fuels. The filter bases I am using is a WIX 24770 due to the fact the nipple is a pretty standard 1"x14. My goal was to use items that avoided "specialty" parts, so I can get them at most places. The primary filter is a WIX 33439 which carries a 10 micron rating and has a water separator feature built in. The secondary filter is a WIX 33674 which carries a 2 micron rating. These four items has so far cost me $68.59 with tax. I have yet to drop in at the brass shop for the serious abuse on my wallet. Pics will be posted later after I sucker "BrianS" into welding up the framework for all this.
Now the second part....
Obviously there are some pretty serious concerns on running WMO in your tanks. Outside of the grit in suspension, there's pretty toxic chemicals also in the drain oil. Currently I am working on finding a filter for the acids present but that may be cost prohibitive. What the filter rig will handle is the water, and the grit down to 2 microns. The factory filters on our trucks have a larger rating than what I am working with. The WIX 33617(7.3) seperates the water and the grit down to 12 microns. the WIX 33811(6.9) filters the fuel only down to 6 microns. So, if all works the way I hope, the filtered WMO will be clean enough to used in the truck.
well....
that's all for now. I will post more later. Feel free to ask any questions and I will try to answer the best I can.
well....
...Towcat, your system sounds like it will do the trick....Cheap, simple, portable and effective. I can filter mine right into the tank to avoid the gas cans.
