No power to ip
buddaniels
wi
Hi all .i have a 90 idi. I ran a wire from my electric fuel pump to my switched wire on the ip. I think that wire grounded out and now i have no power to the ip . Any ideas?
The key switch hot wire is protected by a fusible link. Typical circuit below. Get out your test lite or VOM. Check all fuses.
FORDF250HDXLT
Maine & Oklahoma
you can't run direct power off from the FSS line like that or you'll overload the circuit.you need to draw directly from a stronger circuit or off the battery directly.if you want to setup a relay,you can use the FSS line,but only as a way to tell the relay to turn on,not draw from.
more details can be found in the tech articles,under installing an electric pump.
crispy74
