sw114702
Well let me start by thanking everyone for making this such a great resource and thanks in advance for any feedback.
About me: I'm in my late 20's and live near Peoria IL. I love diesel engines and antique cars.
About my Truck: Just picked up a 1993 Ford F250 4x4, 5-speed, 3.55 gears, 215,000 miles. Originally a NA engine but a factory ATS 093 (correct me if I'm wrong) was added on 100,000 miles ago. At the same time I'm told that the clutch was replaced and an upgraded solid front axle was put under the front. It was used on a farm at some point for clearing snow which is why it still has the boss front plow mount/wiring which I will be removing to hopefully get some money back. Along with this truck I got a complete 7.3 NA out of a 91 truck that I have for parts. It is supposedly a good running engine with no major issues, although I never heard it run myself.
It seemed to run and drive pretty good when I brought it home but once I tried to start it cold the first time it had alot of trouble. I found out that 3 of 8 glow plugs were burned out so I replaced them and now the WTS light doesn't just click/flash and it starts easier so I think I'm good there.
Issues it has:
BODY RUST - probably not going to fix cause it is afterall an IL truck
Whole rusted through the passenger side exhaust manifold (see pic). I have a good manifold on my parts engine but it looks like I will have a tough time removing the old one. The bolts don't look very healthy, any advice? Heat them, cut them off, remove the head, leave it alone? It looks like I would have to remove the inner fender and go through the wheel well to work on it, probably have to tilt the engine a bit to get it away from the frame rail too?...
When I removed the air box I found the nasty turbo compressor wheel surprise (see pic). The wheel is damaged, I don't know if it is wear or of something touched the wheel to mow it down like that. I am assuming it has been that way for quite a while and will not blow apart immediately but I doubt it is something I can leave alone either. Would I be able to replace just the compressor wheel without removing the turbo. It does not look like a fun job to try to remove because the down pipe an Y pipe will not come out easily. Any advice here would be very helpful...
Finally, there is a small fitting on the turbo compression chamber/hat with a plastic line coming out that was lying there broken, can you tell me what that is for and where that line was supposed to run to?
Thanks!
Issues it has:
Thanks!
