John Lahore
From reading this post from the beginning my guess is timing of lack of fuel. Lack of fuel can be anywhere from the tanks to the filter or weak lift pump. Even a crushed fuel hard line somewhere or that short rubber hose from the frame to the lift pump. Timing is the best way to know for sure you are getting the best hp and mileage from you engine. Doing it by ear is at best just a wild guess. Right now on ebay is a kent moore J33300 meter for less than 100 bucks.This is the meter I rent out for less than 100 bucks too.
I replaced the short hose to the frame with a loop, since I couldn't get it on without kinking.
Could be the lift pump, it got a bit bent when the engine was pulled at the wrecking yard.
I am already looking at the kent moore, I sent him a message to see if he has the 1/4" clamp, I can't see it in the photos.
If I get it, can use it on my CAT? I think it has 6mm fuel lines. Have to get the other clamp.
