Dirtleg
I received my new to me injection pump on friday. This afternoon I removed the old pump. While moving some of the parts around from the old pump to the new pump (solenoids and TPS) I realized the new pump has a kickdown lever on it where my old pump does not. The truck is a 93 f350 4x4 E4OD.
My instincts tell me the kickdown is for a C6 which would mean this is a 6.9 pump. Am I correct? Is it okay to run it or do I need to get a 7.3 pump.
I need an answer quick as the truck is apart and I need to make some decisions really soon.
If it will help at all I have the numbers off of the pumps.
New pump;
DB2831 4703 J
Serial # 5998714 Manufacturing # 1809121C92
Old pump;
E3 DB2831 5013 J
Serial #7499648 Manufacturing # 1816521C92
Other differences are the size and shape of the fuel inlet manifold on the back of the pump. It is a little longer than the pump I took off. Not much but noticable.
Also my old pump has what appears to be (it's covered by a plastic guard thingy) another adjustment screw on the back of the pump main body set at an angle. The new pump does not have that.
Hoping I can get some idea of what I've got.
If it is the 6.9 pump can I just turn it up to make it work?
New pump;
DB2831 4703 J
Old pump;
E3 DB2831 5013 J
