Need a Radiator
TLBREWER
Windy B Ranch
Moriarty, New Mexico
I just tried the radiator.com thing. That was pretty cool, except that no one answered the phone. However, the online quote was $227.90 which is good if the quality is up to par.
Thanks all.
GenLightening-
I want to go with new, but thanks for the offer.
Tom
tonkadoctor
none ya bidnes
Thanks all.
GenLightening-
Tom
Call them, their online quotes are a little BS and often not accurate, Over the phone you may get several quotes for different warrenties, radiators etc. While the "Chat" seems real, you're talking to a computer, not a human.
MIDNIGHT RIDER
WE AIN'T WAITING ON ME
I got to thinking on how possibly rotten and stopped-up my old 22 year-old radiator was getting, and of how I was courting imminent radiator disaster; so, I just stopped at Advance, this morning, and picked up a new radiator, Ready Rad # 432194.
I got a few more ducks to get lined up, before I install it, such as a good system flushing, some re-plumbing, heater-core bypass, by-pass coolant filter, and a controllable bottom drain that drains in an empty jug instead of all over the ground and me.
It makes me feel better, having it on hand, just in case I have to call home and have it brought to me, in a coolant emergency.
MIDNIGHT RIDER
ONE LESS THING TO WORRY ABOUT
I stopped at Advance and picked up a new radiator, Ready Rad # 432194.
I installed my new radiator.
I added a 1/4"NPT two-inch long nipple, female-female cut-off valve, street-ell turned down, 1-1/2" nipple pointed down, and just in case, a cap, all made of brass; all this took the place of the usual pit-**** drain that sprays anti-freeze everywhere but in the drain-pan.:puke:
Now, I can drain as little as a drop, or as much as a gallon at a time, and drain it straight into a jug, instead of all over the ground, me, and the bottom of the truck.:thumbsup:
While I had the coolant out, I installed a ball-valve cut-off in the HOT heater-hose, thereby cutting the hot coolant out of the cab, in the summer.
That alone was worth about ten degrees at the A/C vents, according to the dial thermometer that resides in one of the vents.;Sweet
I also removed and washed out the recovery jug; there was a ton of rust collected on it's sides.
So far, I haven't seen any ponds of antifreeze under it.
:D
Blind Driver2
New Albany, In
Bump.
I just installed a Spectra from AZ in my truck. It's all aluminum, same the same or similar fin count, and the core is just as thick. Looking from the top, I can't tell how many rows due to the slits being much longer.
MIDNIGHT RIDER
It looks like it has been six-and-a-half years since my new Ready Rad radiator and it is still going strong.
Vincent
