BeastMaster
Be prepared to replace if you see mineral deposits.
1994 E350 IDI. Mine had tiny leak when I bought van 10 years ago. Took it to radiator shop, copper core was severely work hardened. Seemed internal buildup of scale was the only thing holding it together.
Descaled it only to have it leak like a sieve. Ended up recoring it.
It was quite easy to make another leak with a small screwdriver. A fingernail may have been sufficient.
I guess the old one went back to the smelter along with ore.
It's been 10 years now. I see new corrosion internally ( solder bloom ? ) and have been investigating if another flush may be called for before it plugs - and what chemical is "safest". Strong enough to make the corrosion material water-soluble, but leave the seals alone.
For me, I believe a Formic Acid based descaler is best. I listed other candidates above in case anyone else cares to confirm or warn me of my error. I haven't met anyone who can explain to me any chemistry backing their advice so I have been falling back to what I know of Chemistry, along with ChatGPT queries.
The Formic is not cheap, but it's sold on Amazon, and I note it's used in descaling of industrial heat exchangers.
I'll chemical descale first, but if I open up a bunch of leaks oh, well it was gone anyway. Formic is not a biohazard, but I may have to be careful if it dissolved heavy metals.
