N/V/H Poly vs Rubber bushings
Bushing material
  • Total voters
chillman88
Central NY
Alright folks, I'm going to be replacing leaf spring bushings on my F350 during part of the 4x4 conversion.
Poly or Rubber?
These things ride on the rough side already. I'm leaning towards Rubber for ride quality but figured I'd ask the group for opinions. I didn't really notice any difference on the Chevy, but that rode pretty smooth from the beginning anyway.
I've got the poly body bushings and have toyed with the idea of putting rubber back in. I don't have any squeaking issues or anything, just thinking it might help the ride. I probably won't though considering the prices I've seen on rubber body bushings.
subway
be nice to the admin :D
York PA
i don't have any real personnel experience running poly but have heard of others with squeaking and even trouble tracking down the road since the poly spring bushings had an angle machined into them.
i think you will be fine either way but have preferred rubber bushings in my stuff over the years.
frankenwrench
overkill is under rated!
Weatherford tx
Poly has served me well, but I had a leak somewhere and my new bushings that were "oil resistant" were not all as advertised. And yes I had an issue with the squeezing but typically ignored it. Rubber bushings have not improved ride quality, but hopefully they last more than 4 years with the dust, grime, and other oily substances that my truck periodically likes to leak. We will see....
chillman88
Central NY
Do you remember which brand you used?
kuskoal
Yokosuka, Japan
Poly bushings for the win. On these trucks it takes a LOT to improve ride. I had to do the 05+ swap with Carli(read: VERY high quality) springs all around, and it still rides a lil rough.
Poly bushings will not deform or fall apart, unless you use the wrong type of grease on the inside. Oil and grease don't really affect it and lasts a LONG time.
frankenwrench
Weatherford tx
Believe it or not, energy was the brand I used. Lol.
It was diesel and oil that made its way through the bed from engines and transmissions I throw back there regularly. Even old hydraulic pumps. Definitely not proper grease. Lol. Still took 4 years to deform my bushings.
I'm almost certain (at least 97%) that I'm going to use rubber ones when I go through the front end on my truck here in another couple of months. I figure that if they've lasted since 1985 and aren't completely shot, then they should last long enough for me. They may even outlast me.:dunno
Fordman1920032003
Arkansas
I did poly when I redid the front of my bronco. Been a year of daily driving and I still dont get any camber when I back up. Also my tires quit cupping.
jrollf
Houston, TX
I completely replaced all the bushings in my front end with poly probably 5-6 years ago and have been very happy.
Replaced the cab mounts with poly this year and have been happy so far. However I don't have a 4x4.
1993 F350 Crew Cab Dually
XLT
7.3 Factory IDIT w/Banks Sidewinder
5spd Manual
ifrythings
BC
Your expectations of today’s rubbers are high
  • Like
Reactions: dgr
olsen726
