jam0o0
ok back from the dead.
good news:
-B&W turnover ball installed. man is that thing well thought out.
-40 gallon in bed tank is in.
-electric pump is in and working. the fuse and relay for the pump are in the factory engine bay fuse box. using factory connectors and wires from a junk yard truck.
-i've got a 5 micron filter before the pump. all mounted below the fuel level in the front tank. 3/8" fuel line all the way from the tank to the high pressure pump.
bad news:
-i get fuel pressure into the input of the moose pump. but no fuel to the return line on top of the pump. and no fuel to the injectors. this is after a minute of cranking. should it take this long to get the high pressure pump filled up? the shut off solenoid is getting power. that is what i'm using for the trigger for the electric lift pump.
help. i'm out of ideas.
good news:
bad news:
What did you do with your CDR? If I missed it before sorry.
