those are some nice gauges , ill stick with my dummy sticks though , they haven't lied to me yet.
Really....
i would like more torque because i have 3.31 geared rearend and a c6 for good freeway travel, however with this combo there isnt much pulling power. Or how about a non electronic overdrive trans adapter? like the AOD or GM 700R4? I know theese can be built tough for a stock IDI.
the aftermarket gauges are great and when my dummy sticks fail me ill put something better in they're place , just sayin the two times my idi had problems ,my dummy sticks let me know . like i said they haven't let me down yet.
id get moose ip type4s cam and high pop injectors around 2100 psi
then add a turbo of youre choice and youll be fine with that truck
if you want to tow a lot more get 4.10s and a gv
or do as i got a stroker kit my engine is 7.6l and it makes a world of difference
with a bad ip timed to - something and fuel screw untouched open exhaust and 3 in tall air cleaner i keept up going up hill with
a stock na truck with good ip and fuel screw cranked open exhaust with e4od
Yes... The higher pop pressures make for a finer atomized fuel spray so it ignites easier but... Too high of a pressure and the pump will wear out much sooner. The electronic diesels from the big three all pop at 20,000 lbs or higher and they have multi port nozzles. The nozzles have micrscopic ports in them. Some aftermarket injectors pop at 40,000 lbs....
I had a oil pressure gauge with the plastic line and when it got brittle, it cracked, spewing hot, stinky oil all over the interior...Mudduck... Thats not an oil pressure gauge... Thats an idiot lite with a pointer....Heres an oil pressure gauge.... when it works....
Does anybody else have experience with this mod? It makes sense to be a natural fit, especially for torque. If it dropped the cr down to 19:1 or so that probably would help too.Yes... The higher pop pressures make for a finer atomized fuel spray so it ignites easier but... Too high of a pressure and the pump will wear out much sooner. The electronic diesels from the big three all pop at 20,000 lbs or higher and they have multi port nozzles. The nozzles have micrscopic ports in them. Some aftermarket injectors pop at 40,000 lbs....
. Hmmm, maybe the stroker crank is a piece of the puzzle we're missing.Does anybody else have experience with this mod? It makes sense to be a natural fit, especially for torque. If it dropped the cr down to 19:1 or so that probably would help too.
