I have made the decision to just stick the rusty ole brick nose rad support in for the time being.
It is time I start preparing for a turbo with IC install.
With the above said, I decided to bone the 92-98 rad support, and start to modify it to fit the 6.0L IC I procured.
So the process has begun and without further addo....you guessed it...PICS
Here is the stripped down support with two light cuts on the edges for IC In/OUT tube clearance, notice the foot near the cut on the right!
Here I point to the other side...I am not differentiating drivers from passengers side at this time in descriptions, this is just L or R in the pictures
IC now fits into the rad support, there is a difference in location from one side on the IC to the other and diamter as well..
These end close ups show that there is good clearnce, I feel that doing this OFF the truck allows me to do a very nice job, plus this support needs a little massaging anyway and then some light sandblast and paint, so do the fabbing now!
Now this shot was to point the IC mounts I will have to fab up. However I did not have the vertical support bar in the middle of the rad support in when I took this picture, that's why the IC is so close to the support at this point. I may go to the wrecker where I got the IC and see if I can cut these parts off or at least take some pictures of them. Pictures would make it so much easier to fabricate for sure and parts would maybe take just a little bit of mods to fit!
Here is the upper portion of the IC and I sat the vertical support bar in place
Here are a couple of side shots with that vertical bar in place!
Over all I think this will work extremely well. The down side at this time, HEADLIGHT bar...but that...is another fab article!
Al
Al
all over yerselves if it turns out as well as I imagine it should look!
or...Or...OR...cut and hope for best. I will see if I can figure out something..angle outlets on IC...etc but these pics depict where I theoretically have to cut the rad mounts and thus loose strength...
