So I am losing my fuel pressure after I shut 'er down. What are these caps you guys are talking about that I should replace. It has a pump similar to this pushing fuel to the fuel filter. http://www.napaonline.com/Search/Detail.aspx?R=DFPFD0002_0218385030
I don't really know where to start. It starts really hard, I assume because it loses the prime while not running. Brand new glow plugs and it glows for a healthy 10 seconds or so. It takes over a minute of cranking to get it to start. It will usually stumble after 20 seconds to start though. I do not crank the starter for even 30 seconds at a time though.
Also I am in need of some new batteries. I read about these group 31 batteries. Can someone elaborate on that for me please. Is there any reason I shouldn't just get two autozone yellow tops at about 850 CCA's each?
Also any water left in the glow plug wells at the heads will cook off....
