HammerDown
Since new in 1988 I've dealt with the usual leaking return lines/O rings but, this time I can't figure where the fuel smell is coming from and air is getting in.
After several days of sitting, it loses prime... fires then dies... crank, crank, crank and fires and runs fine.
I smell raw fuel but can't find the leak.
Return lines/o rings dry, fuel filter/water seperator dry,, lines going to and from fuel tanks dry, fuel tank selector valve dry, but I smell raw fuel. I even changed the lift pump... same dilemma.
