zmck150
I've done a lot of reading on this forum and gotten tons of great information and now I'm finally getting close to being able to purchase a turbo setup. Hopefully some of you guys will have some pointers or suggestions.
My truck as of now is a 1993 f350 crew cab long bed dually 4x4 with a 7.3 n.a. idi attached to a e4od. I'm not 100% sure but it seems like my truck has some trans work done ( low stall torque converter) And oversized coolers. The 7.3 is a jasper reman(unfortunately) but at least it Is the 185hp with a serpantine belt setup.
Now I have another 7.3 I purchased with low compression. I'll be taking that one apart in the next couple days to find out what is wrong with it. Assuming nothing is cracked, no cavitation, etc I want to put new bearings rings arp headstuds and all new gaskets on it. Purchase a stock turbo kit and put code bb injectors with the pump from the jasper (in the truck right now)
A couple concerns I have would be the ip from the jasper not be enough for the turbo setup? My goal is like 225-250 at the wheel in best case scenario. I don't want to slow down like crazy goin up hills anymore and a couple more mpg would be Cool also. My next concern is the engine I picked up is a v belt setup, from what I've read I can just swap pulleys and accessories and I should be all set to keep the serpentine setup.
Any input or corrections is greatly appreciated
Sent from my LG-P659 using Tapatalk
